i am currently trying to make a project that replicates a firework that disperses when it explodes. the idea behind the throbing led's is the brightest peak would be like the explosion and it brightness will fade.
is there anyway that this task can be accomplished with the use of a 555 timer and a 4017 decade counter?
I am limited on IC which i can get so i was hopin that these two chip's with some other components could do it.
if this can be done, some little adivice would be greatly aprreciated thank you
