This serial capture works, but I do not understand why....
Gibson486
Joined Jul 20, 2012
360
I had to get a serial string on an arduino and read it back out.
This is what I got to work...but I am confused.
Code:
   char buf[MAX_MESSAGE];
   char readS;
   int count = 0;
   while (Serial.available())
       //read what is in buffer when something shows up
      readS = Serial.read();
      delay(5);
      if (readS == '\r') {
        Serial.print("You entered: ");
        Serial.println(buf);
      else {
        if (count < MAX_MESSAGE-1) {
          buf[count++] = readS;
          buf[count] = 0;
I am a little perplexed at the "else" statement...
1. Why do you need buf[count] = 0?
2. Doesn't doing the count++ make the next count equal to that? It works, but I thought it would turn the that value to 0 immediately.
3. Wouldn't this code always lead to buf[0] being 0? since it stores at buf[count++], wouldn't the first stored value be at buf[1]?
michael8
Joined Jan 11, 2015
472
This makes sure the string in buf has an ending 0 byte at the end of the current valid data.
Serial.println(buf); is going to print the characters in buf until it hits a 0 byte. See the arduino reference for string.
https://www.arduino.cc/reference/en/language/variables/data-types/string/
2. buf[count++] = readS;
count++ increments count but the count gets used as the subscript *before* it's incremented.
This is call post increment.
3 No, it puts the current character in readS into buf[count] and sets buf[count+1] to 0.
Gibson486
Joined Jul 20, 2012
360
Thanks! explains a lot!
