Yes, a battery has (gives) voltage, even when it is an open circuit.so I need to calculate this loop:
But it is an open circuit, does the battery give voltage? does the 4\Omega resistor drop voltage?
This diagram has I2 as the current flowing downward in the 2 Ω resistor. But in your original diagram I2 was defined as the current flowing to the right through the adjacent 4 Ω resistor (the one to the left). You need to be consistent in your use of variables.so I need to calculate this loop:
| I | RC - Thevenin Equivalent Analysis | Homework Help | 12 | |
| F | Thevenin HW Example | Homework Help | 1 |
| Similar threads |
