In post #9, I said "In your circuit if you remove the 12Ω resistor from the a-b terminals, and then replace the 80 volt source with a short circuit, and the 8 amp source with an open circuit, the resistance looking into the a-b terminals will be 4Ω; this is Rth (or Req).".For this question the load is given, but not all thevinin questions have the load given. If no load was given the question would just state find Eth and Rth for this circuit and hence find 'I' if a certain R(load) is connected. Is that possible with this circuit?
OK bare with me..Then I said "To calculate the open circuit voltage, notice that the 2Ω resistor has no effect. Then calculate the voltage drop across the 4Ω resistor. If the 12Ω resistor is absent, how much current will there be in the 4Ω resistor?
If you know the current in the 4Ω resistor, you know the voltage drop across it.
That voltage drop is in series with the 80 volt source, so what will be the voltage seen at the a-b terminals? This will be Vth (or Veq).".
In post #20, I explained "...a resistor in series with a current source causes some extra voltage drop in the branch containing the current source and the resistor in series with it, but it does not change the current coming from the current source. It has no effect on the rest of the circuit".
Thus Eth is found with the load resistor disconnected.
This circuit is so simple that Rth and Eth can be found by inspection. But, there is no reason why it can't be done with nodal or mesh analysis. Just because a circuit has some particular resistor missing doesn't prevent the calculation of the voltage across the terminals where that resistor had been connected, by nodal or mesh analysis.
If you didn't know that this was a Thevenin problem, and there was no 12Ω resistor, why wouldn't you be able to solve the circuit for all the node voltages and mesh currents?
If you had produced your work, this discussion wouldn't have lasted 30 posts.nice one bud.. forgot to add rth
OK bare with me..
'I' in 4ohm is 8A??
vd in 4ohms is 8 x 4 = 32v??
if in series and is added to 80v = 112 which is wrong...
| Thread starter | Similar threads | Forum | Replies | Date |
Thevenin Theorem problem | Homework Help | 1 | |
| E | Thevenin's Theorem | Homework Help | 5 | |
Problem with Thevenin Theorem with only dependent source | Homework Help | 6 | |
Thevenin Theorem example quesiton! | Homework Help | 11 | |
Simplifying circuit for Thevenin theorem | Homework Help | 2 |
