Thermoelectric Device, how to test one
Gdrumm
Joined Aug 29, 2008
684
A wine cooler stopped working, and I took the back off, and found the boards.
I found and unplugged one lead of a thermoelectric device that converts heat to cool, or vice versa.
When I did, things started lighting up, as though it was turned on (but it wasn't cooling)..
I tested the ohms of the device, and it started at about 38, and began to drop slowly.
When I hooked it up to 12v, all I got was a repeating beep.
When I hooked the Pos. wire to Pos. on my meter, and neg. to neg., the meter also beeped (as though a direct short).
Is the device bad? (I found some on ebay pretty cheap, and I'm pretty sure I can put it all back together correctly.)
The wine coolers sell for anywhere from $50.00 up to $500.00, so if I can get it working, that would be cool.
(pun intended)
Thanks
Gary
18,125
The TEC should show a DC resistance of about 1 ohm. A value of 38 is too high for the module. What beeped on 12v?
In my opinion the TEC is possibly ok but places too great a load on the power supply. That's where the problem is. But are you saying that everything works fine as long as the TEC is not connected?
34,892
Testing a TEC is simple.
First of all, you want to derate the unit. For example, if the TEC is a 12V, 12W unit, derate it to 6V, 3W.
Use a fixed 6-9V power supply (or a current limited supply) and connect to the two leads of the TEC.
Very quickly (within a matter of seconds) one side should feel cool while the other side runs hot. Don't run this test for more than 10-20 seconds to avoid damaging the TEC.
18,125
A 5V supply from an old computer PSU works nicely for testing a 12V module. As noted, just a few seconds to feel cold on one side and hot on the other.
