Thermal analysis in TPS7A3001DGNT
engr_david_ee
Joined Mar 10, 2023
364
I have some questions regarding thermal calculation for the voltage regulator TPS7A3001DGNT.
\[ P_D = ( V_{IN} - V_{OUT} ) ( I_{MAX}) + (V_{IN} ) ( I_Q) \]
What is \[ I_Q \] in the equation above ?
engr_david_ee
Joined Mar 10, 2023
364
Also, the equation (10) it says.
\[ T_T : is \ the \ temperature \ at \ the \ center \ top \ of \ the \ device \ package.\]
\[ T_B : is \ the \ PCB \ temperature \ measured \ 1 \ mm \ away \ from \ the \ device \ package \ on \ the \ PCB \ surface. \]
Are these both temperatures representing temperatures at power off state ? which can be lab's room temperature ?
Papabravo
Joined Feb 24, 2006
22,113
It is the quiescent current required for the operation of the regulator. You can find this value in the datasheet.
Papabravo
Joined Feb 24, 2006
22,113
No. Those temperatures are when the device is in operation. Neither of those temperatures are the ambient or room temperature.
engr_david_ee
Joined Mar 10, 2023
364
Regarding T_T and T_B, you mean when the device running with full load ? then it will be much higher. If we don't have the PCB, actual hardware then how do we find these temperatures when working on schematic and PCB design ?
Papabravo
Joined Feb 24, 2006
22,113
You estimate them and provide for some safety margin. You can usually get junction to case or junction to ambient thermal resistances from the datasheet. For example if you have a maximum junction temperature of 125 °C and a thermal resistance of 62.5 °C/watt for junction to ambient and the device is producing 0.75 watts at a room temperature of 25 °C, then your estimated junction temperature would be:
\( 25\;°\text{C} \; +\;0.75(62.5\;°\text{C/watt})\;\approx\;72\;°\text{C} \)
Since this is well below the maximum junction temperature you would be safe in not using a heat sink.
ETA: That does not mean you should put your fingers on it for test purposes since you might still get a NASTY burn.
