Hi, I'm new here, i'm having difficulty completing a program on my own. I was given a task to complet 3 programs. I've completed the first 2 but having problems with the last one. Can anybody help me out here? The description of my tasks are below:
Hardware Configuration
The hardware configuration of the 68000 applications boards in the laboratory are as shown in Figure 1. Data to all four seven segment displays is supplied via PortB. A display is activated by outputting a logic 1 on the corresponding Port C control line e.g. outputting a logic 1 will turn on the LSD (Least Significant Digit) display.
Experiment
1) Develop a 68000 assembly language program to produce a count down sequence on the LSD seven segment display after switch connected to PC4 has been asserted.
2) Develop a program that will display the hexadecimal equivalent on the LSD seven segment display of any binary input from PortC bits PC4 to PC7.
(Hint: Use MOVE. B (A0,D0),D1 - Move the byte value from the memory location pointed to by A0 + D0 into D1 where D0 is the four bit value read from the switches).
3) Complete a program that will read any byte value from PortC and display the corresponding hexadecimal values on two seven segment displays. It will be necessary to time multiplex the displays so that the correct value is displayed on the right display at the right time.
Like i mentioned earlier, i've completed task 1 and 2 but i'm stuck with task 3. The circuit diagram of the 7-seg is attached below as well as the program for task 2. My lecturer told me that tasks 2 and 3 are similar but no matter how i tried, i still can't make it work. So if there's a kind soul out there, please help me out I'll be so grateful to u The attachments are below. Thanks.
Hong
The task 3 flowchart
__________________
H.Zhang
Experiment
Hong
Rich (BB code):
Task 2 program:
PBDDR EQU $A00007 ; DATA DIRECTION REGISTER (TO CONFIGURE I/O)
PCDDR EQU $A00009 ;
PBDR EQU $A00013 ; ADDRESS OF PORTS AS SHOWN IN DIAGRAM
PCDR EQU $A00019 ;
ORG $400400
MOVE.B #$FF,PBDDR ; SET PORT B AS O/P
MOVE.B #$0F,PCDDR ; SET PORT C 0-3 0/P, 4-7 I/P
MOVE.B #$01,PCDR ; ENABLE LSD OF 7-SEG DISPLAY
BEGIN LEA DATA,A0 ; DEFINE DATA ADD
CLR.B D0 ; RESET D0
CLR.B D1 ; RESET D1
MOVE.B PCDR,D0 ; GRAB 4 BIT DATA INPUT FR ABITEC
ASR.B #4,D0 ; SHIFT 4 BITS TO THE RIGHT AND.B #$0F,D0 ; MAKE LEFT 4 BITS TO BE 0
CHECK SUB.B #$00,D0 ; CHECK I/P NO.
BEQ DISPLAY
INCR ADD.L #$01,D1 ; INCREASE DATA ADD BY $1
SUB.B #$01,D0 ; SUB I/P NO.
BNE INCR
DISPLAY ADDA.L D1,A0 ; ADDING DATA ADD
MOVE.B (A0),D2 ; LOAD THE DATA
MOVE.B D2,PBDR ; DISPLAY DATA
BRA BEGIN ; RESTART
DATA DC.B $3F,$06,$5B,$4F,$66,$6D,$7D,$07
DC.B $7F,$6F,$77,$7C,$39,$5E,$79,$71
END
__________________
H.Zhang
