The radiation pattern of two parallel dipoles in out-of phase by 180 - one inverted the other
Bavlos
Joined Mar 2, 2020
14
Im trying to draw the E and H plane for radiation pattern for two-parallel-dipoles-in-out-of-phase-by-180, in other words I have two inverted anntena dipoles with same distance from each other in parralel, what's the maximum direction for max power? how could I find the radiation pattern? I have solved the question and the result was that the radiation pattern is a circle with raduis one, but the result is really something else and I don't know how to arrive to the result...
conceptual if they are inverted then I dont have any radiation - one is inverted the other ..-
thanks for helper
Alec_t
Joined Sep 17, 2013
15,112
I don't have the answer, but surely the distance between the two dipoles will dramatically affect the result.
