calculating vissually axial ratio frm radiation pattern
yef smith
Joined Aug 2, 2020
1,481
Hello,In anechoic chamber we are testing the antenna using a test antenna,in our case if we design circular patch antenna then we test it with circular antenna.In cst i think this option is as shown bellow.It gives me some radiation pattern as shown bellow.
I dont want to use the axial ratio option in CST,I want to calculate the axial ratio from the radiation pattern.
Axial ratio by definition is the ratio between electric field components.
How do i see the axial ratio from the radiation pattern shown bellow?
Thanks.
Tesla23
Joined May 10, 2009
560
In that
In that case you need to work it out from the relative amplitudes and the relative phases of the two orthogonal linear polarizations. Check out the definition of circular polarization.
yef smith
Joined Aug 2, 2020
1,481
" relative amplitudes and the relative phases of the two orthogonal linear polarizations "
Yes, how can i do it in CST?
Thanks.
