Switch on/off is ambiguous and it's tedious to read your descriptions of how things are connected. Post a schematic.Still not owrking, one switch is off, goes to the 13th pin, 13th pin is 4.95 V, one switch is on, goes to the 12th pin, 12th pin is 0V, 11th pin (output) is 0V. I used 4.7 kilo ohm resistors
Read the data sheet.Oooohhh.... So that resistor is what was the problem now it works thanks guys xD...
I also got 74HC86N today (also xor gate)
and it works fine without output pullip resistor.
And some 74LSxx I used and and or ones also didn't need output pull up resistor why does 74LS136N need one
