I have designed this PCB for my project and when i connect ESP8266 NodeMcu along with LM35 temperature sensor and check the output on the serial terminal the output drops to 0 v. I have checked the schematic and found no short. and connected the esp along with LM35on breadboard with the same code and found the circuit to be working correctly. kindly help me to find the bugs in this.
