The only not human is you, stupid compfuser !
WBahn
Joined Mar 31, 2012
33,209
I get those a lot -- I'm guessing it's a Cloudfare thing. Frequently, they don't ask me to even click anything. It pops up saying that it is verifying that I'm human and then a couple seconds later proceeds to load the site. So... just what kind of "verification" did it do?
Ya’akov
Joined Jan 27, 2019
10,303
That is one appearance of the Cloudflare human verification process. It is a layered, progressive scheme to eliminate bots from accessing websites.
What you actually see depends on how your browser scores as the process steps through. In a nutshell, this is what happens:
1. Initial Request Inspection (Server-Side)
Cloudflare evaluates the request before anything loads:
  • IP reputation & ASN threat history
  • Geo-risk & TOR/VPN/proxy indicators
  • Rate-limiting / WAF rules
  • Domain-specific security settings (Managed Challenge, JS Challenge, CAPTCHA)
If risk is low, the user passes immediately without seeing anything.
2. Browser / Device Fingerprinting (Passive)
If the risk score is borderline, Cloudflare asks the browser to run a lightweight check:
  • User-agent consistency
  • TLS handshake & JA3 fingerprint
  • Cookie presence/consistency (cf_clearance, _cf_bm)
  • Screen, timezone, platform coherence
  • Accelerator/hardware concurrency
  • Headless/browser automation indicators
No interaction is required. If values look human/benign → pass.
3. JavaScript Execution Test
If uncertainty remains:
  • Cloudflare embeds a short JavaScript snippet (“Managed Challenge”).
    It runs micro-tasks:
    • Compute tiny cryptographic or timing puzzles
    • Measure JS execution timing jitter
    • Confirm real event loop & rendering engine
    • Validate local storage/cookie write capability
Bots failing JS → blocked
Humans → pass within ~1–3 seconds.
4. Cryptographic Proof-of-Work (Invisible to Humans)
When configured, the browser performs:
  • A small, low-latency proof-of-work (hash-based)
  • Cloudflare checks the solution signature and timestamp
If solved → clearance cookie issued.
5. Interactive Challenge (Only if Needed)
Only after passive and JS checks fail:
  • Turnstile (Cloudflare’s CAPTCHA-less system)
    • Uses behavioral signals + device data
    • Typically solved with no interaction
  • hCaptcha (legacy mode)
    • Presents image-recognition tasks
    • Used only on high-security settings or when Turnstile can’t verify
Users solve → clearance cookie issued.
6. Clearance & Session Continuation
Once verified:
  • Cloudflare sets cf_clearance and/or _cf_bm
  • Future requests bypass challenges for a set duration
  • Revalidation occurs if:
    • Cookies expire
    • IP/network changes
    • Suspicious behavior reappears
Optional: Higher-Security Protections
Depending on zone settings:
  • Browser Isolation for unknown clients
  • Bot Management behavioral scoring
  • Device posture checks (enterprise)
ZCochran98
Joined Jul 24, 2018
356
At work due to the layers of network security we have in place, EVERY time we try to use Google we have to play "find the buses." I had a colleague spend 15 minutes doing Captcha after Captcha once. So...it could be worse.
