The minimum voltage in 3 pin regulators as 7805...
Externet
Joined Nov 29, 2005
2,662
Hi.
Does it apply also when used as a current regulator ?
Am after a 300mA constant current IC capable of doing its work at 2V supply.
Which regulator should be used ?
dl324
Joined Mar 30, 2015
18,446
Yes.
Don't know of any regulators that will operate down to 2V. You don't have much headroom, but you might be able to make one with a PNP transistor.
bertus
Joined Apr 5, 2008
22,985
Do you intend to use a regulator as constant current source?
The LM317 datasheet gives this schematic:
The voltage drop will be the voltage drop of the regulator itself + 1.25 Volts.
Bertus
Externet
Joined Nov 29, 2005
2,662
Thanks.
Yes, constant current source of 300mA from a supply voltage that will vary from ~4.2VDC to ~2.5VDC from a 18650 discharging.
Good to know, Bertus. 1.25V overhead. That should work.
bertus
Joined Apr 5, 2008
22,985
You still will have to take the voltage drop of the regulator itself in account.
At 300 mA that will be about 1.7 Volts.
That and the 1.25 Volts accross the resistor, will give you a total drop of about 2.95 Volts.
Bertus
WBahn
Joined Mar 31, 2012
33,067
Hi.
What's your tolerance on that 300 mA?
How much temperature variation will there be for this circuit (other than self-heating)?
Do have another supply available to power the circuit, or does everything have to come from the 2 V supply?
OBW0549
Joined Mar 2, 2015
3,565
An LM134/234/334 makes a handy constant-current source capable of operating with as little as 1.0 volt headroom, but by itself it only goes up to 10 mA. However, the data sheet shows how that can be increased by using an external pass transistor and a couple of other parts. See Figure 20 on page 11. This should work down to about 1.7 volts, depending on the Vbe of the transistor.
Externet
Joined Nov 29, 2005
2,662
Thanks again, gentlemen, good assistance.
Tolerance of +/-10 % should be fine. Operating temperature will be ambient outdoor... like -25C to +50C. A single 18650 cell as supply.
The supply will never get as low as 2V, as it is under the discharge limit of the cell ~2.5V, but I was better looking for an IC capable of performing under that value (2V)
Trying now to refine the project, am looking to constant current regulate 300mA with a constant current regulator IC capable of ~1A as safety margin, with a shut-off pin,
'2V' input capable, perhaps LT3083 until I find something more promising.
Code:
Li-ion(+)-------------------------Current regulator-----------------------300mA device---------------------(-)
                                      on/off
                                    control pin
