the cd4066be measured pin1 and pin2 through?
LAOADAM
Joined Nov 21, 2018
956
How much current are you hoping to pass through the IC? Each channel is rated for 10mA max.
I didn't check it yet. I guess 10ma is OK.
but I used a PC817 tested works well.
I was thinking the Optocoupler components can't work same as the relay which is just mechanically contact. not clear whats the difference between them.
ScottWang
Joined Aug 23, 2012
7,505
Optocoupler is used for high speed and lower current than a relay.
Edit: Mostly the relay is worked for less than 10 times(10 on/off) in 1 sec. (<10Hz)
