The Case Against Quantum Computing
So what has it got to do with physics then?
Observation and measurement is why we build things like the LHC, so we can learn new things in physics and verify theories. We needs it to explore reality, not to generate 'reality'.
xox
Joined Sep 8, 2017
936
You've missed the point. The role of "the observer" is one of the cornerstones of "quantum weirdness". I am simply suggesting that it should be thrown out of physical theories.
You've said that several time but it's a meaningless suggestion. People to free to have 'their own' (sometimes mystical nonsense IMO) physical theories, it's just an interpretation.
xox
Joined Sep 8, 2017
936
Remember, QM states that the very act of observation causes wave-function collapse. Thus, the theory itself is flawed because its supposed mechanisms are based on questionable "interpretations". So once again, delete the nonsense, and go back to what is legitimately verifiable.
MrAl
Joined Jun 17, 2014
13,810
OK, but is the "observer" really even necessary from the standpoint of making measurements? Wouldn't it be more concise to talk about the "specific nature of the observation"? That is, we have wires and plates and all sorts of components which inadvertently interfere with a "strictly faithful" measurement. Those objects are of course going to influence the measurement. In that particular respect however, consciousness is of little interest to the physicist. (That said, there may one day be some viable theory which CAN successfully incorporate "consciousness" into the equations. But that would be more along the lines of focusing on the "consciousness of the thing being observed" rather than the "observer of the thing being observed", if that makes any sense.)
I think this point has been argued in the past. I cant remember the name of this particular argument but it centers on which comes first, the brain or the physics. I think it is because when you really get down to it the brain and the measurement are so uniquely tied together that it becomes arguable which one takes precedence. I guess by 'brain' the meaning is the interpretation.
You want to argue that physics takes precedence, while others may argue that the brains interpretation or rendering of the information takes precedence. I dont think this argument has ever been settled though.
Some things can simply never be separated. Maybe this is one of those cases. I'll try to find out again what this argument is called i forgot over the years and years. It may be again one of those pure philosophical arguments which in themselves have different interpretations.
This hints on what i am looking for but dont think this is the entire argument...
Neuroscience Weighs in on Physics’ Biggest Questions - Nautilus
MrAl
Joined Jun 17, 2014
13,810
That was interesting. He was pointing out the difference between a mathematical theory and a physical theory and saying that it's hard to go from the math theory to the physical world.
Maybe that's what we are stuck with. If the world is too complicated it may have to stay that way, where we have certain math that goes with certain physical situations.
The other thing could be the old, wrong person in the wrong industry at the wrong time.
This reminds me of the difference between the people that work in developing secure communications and the mathematicians. The comm people develop a great great idea about how to transmit information securely and believe whole heartedly that it is beyond cracking and publish it with that expectation, only to have a mathematician break the code in an hour. That speaks volumes i think about who is doing what. It's only the ones that can meld both disciplines that make the best history books.
It's interesting that one or two of the biggest problems of our time right now is so practical and doable and yet still not achieved. Secure transmission, secure storage.
I understand where he is coming from about the Copen. interpretation. He believes it is somehow magic and therefore not part of physics, or at least that's how he leans.
I might go that route too if i didnt see some experiments that actually show that there is something that if we didnt know better we would call magic too. There seems to be too many things that just can not be explained using a more reasonable method.
In his favor, the pilot wave theory has been demonstrated by i think it was silicone oil drop on a water surface. Supposedly the oil resonates and makes changes in the water surface which in turn keeps pushing and i guess directing the silicon oil drop along. However, i have also read that the idea does not hold at very high frequencies. It's called the hydrodynamic analogy (i think).
I am wondering now if a true TOE would have to be just a map of theories and physical phenomena that has to be maintained in order to explain the world in full. There may be missing parts we cant see or detect.
It is interesting to talk about this in any case, and as to the wavefunction collapse it still looks to me like an antenna/wave type of action. I am not sure if that is a deep enough explanation though.
Pilot wave is still a 'fringe' theory IMO. It implies faster-than-light signalling is possible and throws a monkey-wrench into causality (discard all of quantum field theory and the special and general theory of relativity). Cats and dogs, living together, etc ...
https://www.quantamagazine.org/famo...ve-alternative-to-quantum-weirdness-20181011/
But a series of bouncing-droplet findings since 2015 has crushed this dream. The results indicate that Couder’s most striking demonstration of quantum-like phenomena, back in 2006 — “the experiment that got me hooked on this problem,” the fluid dynamicist Paul Milewski said — was in error. Repeat runs of the experiment, called the “double-slit experiment,” have contradicted Couder’s initial results and revealed the double-slit experiment to be the breaking point of both the bouncing-droplet analogy and de Broglie’s pilot-wave vision of quantum mechanics.
https://scottaaronson.blog/?p=6957
But if experience has taught me anything, it’s that the quantum hype train never slows down. In the past 24 hours, at least four people have emailed to ask me about a new paper entitled “Factoring integers with sublinear resources on a superconducting quantum processor.” Even the security expert Bruce Schneier, while skeptical, took the paper surprisingly seriously.
The paper claims … well, it’s hard to pin down what it claims, but it’s certainly given many people the impression that there’s been a decisive advance on how to factor huge integers, and thereby break the RSA cryptosystem, using a near-term quantum computer. Not by using Shor’s Algorithm, mind you, but by using the deceptively similarly named Schnorr’s Algorithm. The latter is a classical algorithm based on lattices, which the authors then “enhance” using the heuristic quantum optimization method called QAOA.
For those who don’t care to read further, here is my 3-word review:
No. Just No.
Since this idea needs a name, I’d hereby like to propose Cargo Cult Quantum Factoring.
Back to the original subject of this thread, this may be of interest.
(Awaiting you poo-poo comments NS).
I try not to poo-poo marketing hype efforts. That's a good article but the basic problems with Quantum Computing is not making qubits, it keeping them all in the SAME QM superposition in the presence of noise causing decoherence. It's not like a classical parallel computer where you can break operations into X number of processors.
I need to read the actual pre-print paper a few times but it looks fine as research, converting that to practical engineering hardware, as usual is the deal breaker.
https://arxiv.org/pdf/2201.06679.pdf
Entering a new realm of ultra-fast single spin control
creates new questions regarding the physics of these systems and their application for quantum information processing. For example, the dominant source of control
errors for this resonance method are unknown. Pulse engineering for magnetically driven spin qubits in similar
devices have led to significant improvements in control
fidelity, achieving error rates below 0.05% However,
these strategies can only be translated to the electric
driving approach discussed here once the sources of error
are well understood and characterized.
MrAl
Joined Jun 17, 2014
13,810
I do have to wonder a little why they didnt try using electric fields sooner since the CRT oscilloscope has been doing this since the dawn of time.
Does sound promising just hope it gets us there soon. There have been many promising new ideas popping up in the past and yet we still dont have the entire device.
If we do get there, it's going to radically change things in many areas of technology and life in general, and unfortunately that means in military offence and defense and in highly classified data base hacking. I get this image where some hacker opens up a phone book and turns to a random page and with eyes closed drops one finger down onto the page, then using that name and address hacks into their bank account and uses their credit cards. :)
https://www.forbes.com/sites/rogerh...l-not-break-cryptocurrencies/?sh=73d2817c167b
QM computers are limited problem solvers. It's unlikely there will be a radical change if and when there are practical for the types of problems they can solve. For example there are plenty of cryptographic security measures that QM computers can't crack. Today's (usually Asymmetric encryption public-key algorithms with factorized trap-doors) methods will be upgraded. Symmetric-key-based, Device immutable fingerprint systems will be just as secure post-quantum with increases in key sizes
