The 80s called. They want their store back
THE_RB
Joined Feb 11, 2008
5,438
Actually I was speaking about a piece of paper. It has four sides. You could say it has 3. The outside edge and each face.
Well actually you said the "piece of paper has 6 sides" and "as do ALL pieces of paper".
Specific to my earlier post I reminded you that a mobius strip or whatever they call that trick these days, as a 3D object has 2 sides. And it is a piece of paper. You said ALL pieces of paper have 6 sides. So that was my point, that not all pieces of paper have size sides. A circular piece would have 3 sides, as you later said.
Re the circle, I like the idea that a circle has infinite sides, that makes sense. But a circle also has one side.
So DerStrom8 just proved that infinity = 1. ;)
Since infinity doesn't exist I suppose it can equal anything we like. It can be our own little imaginary friend... Shhhh! :D
DerStrom8
Joined Feb 20, 2011
2,390
Not sure I follow your logic. How does a circle have one side? If you're referring to the face (what's within the outline) then that doesn't count as a side in this case.
Since infinity doesn't exist I suppose it can equal anything we like. :D
Infinity may not be a defined value, but that doesn't mean it doesn't exist.
strantor
Joined Oct 3, 2010
6,875
What a bunch of nerds! Haha, I love you guys. Nobody else could turn a discussion about a superbowl commercial into a heated debate about how many sides a circle has.
THE_RB
Joined Feb 11, 2008
5,438
A "side" does not have to conform to 100% straightness.
So the term "side" must encompass sides that have curvature, and if that is true then a circle has one curved "side".
A triangle has three straight sides. But if the triangle had 3 slightly curved sides it would still match the description of "triangle".
(edit) Actually thinking further I'm going to argue that earlier concept that a circle has an infinite number straight sides.
A straight side must conform to three or more points at different locations along a mathematical line. That situation does not occur at any place around the outline of a circle. There cannot be any straight lines there.
And if you argue that the lines are infinitely short (just pre-empting the responses) that does not hold true as an infinitely short "line" cannot have 3 points at different places along a mathematical line, it can only have 3 points occupying the same point. That is not a line, it is a point.
So a circle has ONE side, which is curved, made from an infinite number of POINTS.
