the 1950's "toaster brake" -- radial saw brake
sn1e
Joined Dec 7, 2022
Hi folks. New to the AAC boards. Not an electronics pro...just knowledgable enough to be dangerous...
I have a 1950 Radial Arm Saw that does not have the modern saw-stopping tech built in. When the saw is turned off, it continues to turn for a few minutes. I found the attached diagram for a way to draw current from the spinning motor after it has been turned off. It pulls that current into a coil that heats up, slowing down the blade. Would anyone on the billboards want to help me find the modern parts to allow me to make the 'toaster brake'? I am not at all sure what these things are. If I had a good diagram, I am sure I could build it and put it into service, eliminating some safety hazards with the spinning blade and making for a nice conversation starter. :)
I have attached the old instructions and picture and diagram of the current switch for the 220v machine.
thanks in advance for any help!
Stephen Neely
Pittsburgh, PA
Woodworker and very amature hacker.
MaxHeadRoom
Joined Jul 18, 2013
30,887
You can get the parts from Digikey.
The Diode rect. is a common item, also the low value 10w resistor in place of the brake element.
MrSalts
Joined Apr 2, 2020
2,767
You can do it by using a DPDT power switch where the second pole is simply connected to a fat resistor 5-10ohm range? This one seems a bit complicated. But, the original power switch would have to be removed from this vintage piece.
power
Brake
LowQCab
Joined Nov 6, 2012
5,102
A separate "Push-Button", which is always "in-Circuit", and ready to be pushed,
even when the Motor is normally Powered, is a very hazardous idea.
The Original-Power-Switch needs to be re-wired to operate a DPDT-Relay
which controls the Power to the Motor,
then a Timer installed to apply the DC-Power to the Motor via a second Relay,
which will be automatically activated, for a pre-set time-period, after the Motor is switched-off.
