TGP2109-SM 8 - 12 GHz 6-Bit Digital Phase Shifter
Ya’akov
Joined Jan 27, 2019
10,350
Welcome to AAC.
Why do you think this is possible? The table is only using 3 bits for changes. If it was possible to provide other angles, wouldnet you expect the datasheet to say so?
The definitive answer will come from the manufacturer. Contact a sales engineer and ask.
28,485
OK, from the data sheet it appears that other phase shift levels are available, but that they are not quite in a smooth sequence. So I suggest going thru a binary sequence and measuring the shift using your network analyzer. In this case it seems that the truth table is rather abbreviated because of the anticipated application requirements.
