Test equipment
Track99
Joined Jun 30, 2022
90
Hello my friends. I want to purchase a device to test transistors, mosfets and capacitors.
Can you recommend any good company brand which has all these 3 in 1 qualities?
Thank you friends.
BobTPH
Joined Jun 5, 2013
11,515
There are tons of cheap no-name devices out there that, I expect, all use the same open source design. They work fine for go/no-go tests and device / pin identification. If that is what you need, I would not spend more than $20. If you want something professional grade, it will be a lot more.
