test diode
Son Gạo
Joined Jun 23, 2019
6
hi all,
i have a problem when test a diode ,
i got bench data with Iin=4.1 Vin=69, but after 7 days current was going down reading is 0.65A. please advise for this case.
thanks
Alec_t
Joined Sep 17, 2013
15,156
Welcome to AAC!
If you post a schematic of your test set-up and a link to the datasheet of the diode you'll have a better chance of a satisfactory response.
Son Gạo
Joined Jun 23, 2019
6
Welcome to AAC!
Hi master,
i noted that,
i will post this datasheet as soon as possible.
thanks
Son Gạo
Joined Jun 23, 2019
6
That is roughly 280W, how does your heatsinking look like? Did you monitor the temperature of the diode?
hi master,
i add the information .
that is a socket which is use in the test.
btw, I will take a photo for board use for this test and post datasheet also,
thanks for support
