Temperature control system project
alexm1992
Joined Dec 19, 2013
7
Hey guys,
It's my first post! I'm am trying to design a circuit where I can specify the temperature of a stainless steel heating coil (2ohm at room temp).
Where i've got to:
I have learnt that the temperature of a coil is related to its resistance levels.
With this formula I have found out what Resistance values are required to heat the coil up to a few temperature levels. For example:
2.6ohm is required to reach 120C.
Now I have what is essentially a small list of resistance values to get set temperatures I'm trying to devise a circuit which can do such a task.
I have only vague memories of electronics from school so any guidance would be appreciated! From some brief research I have found this may be possible via a 'volt devider' or 'wheatston bridge'.
Do any of you geniuses have any thoughts on the best way forward with this?
Alex :)
wayneh
Joined Sep 9, 2010
18,175
Hey guys,
Where i've got to:
Alex :)
I wouldn’t rely on your model without talking some measurements to validate it. Predicting the temperature of a heated wire is notoriously difficult. Depending on what you’re doing, coil temperature may be different than the temperature of whatever you measure with a probe or thermostat.
