temperature coefficient of resistance
murari
Joined Feb 6, 2008
3
hi
i managed to thoroughly confuse myself working on a project on the temp coeff. i hope someone can help......
if Resistance has a linear variation with temperature over a temperature range, alpha should be a constant over this range....
if we are to find R of Platinum wire (say) at 50°C in terms of R at 0°C,
alpha = 0.004
R = R(0°C) * (1+ 0.004 * 50)
= 1.2 * R(0°C)
but if we calculate R at 0°C in terms of R at 50°C,
R(0°C) = R *(1+0.004 * (-50))
= 0.8 * R
This gives me R(0°C) = 0.96* R(0°C) :confused:
can anyone tell me where i went wrong??
recca02
Joined Apr 2, 2007
1,212
there should be zero instead of -50.
where u put -50 is the place where temp difference between ref and the desired value with sign is substituted. it is (Temp(at which R is to be calculated)-Temp(taken as reference))
A (-50) simply means resistance at -50°C....Chill out!:cool:
murari
Joined Feb 6, 2008
3
Sorry... i guess i wasn't as clear as i could have been....
R throughout stands for R at 50°C while R(0°C) is... well... R at 0°C
In the second case, the diff in temp is -50 if i use 50°C as ref temp...
That is, if alpha is independent of the ref temp...
recca02
Joined Apr 2, 2007
1,212
i think the problem here is u're keeping the R constant when changing the reference.
u see at 50°C the ref will change to that value.
in above case u'r ref is seemingly R at 0°C ....say R(0)
in the second case it must be R(50).
and needless to say, they are different.
