Technics SU-Ch9 - using the amp without the modules-- is it possible?
Rabbitbreth
Joined Jan 22, 2019
188
Does anyone know if it's possible to use the amp alone ?
I have the other modules but not sure how to hack the circuit so the amp becomes independent.
any ideas would be appreciated .
Rabbitbreth
Joined Jan 22, 2019
188
and if I find out the voltages ? I guess some current needs to be sent back to the amp.
what can I do if I get those voltages
Dodgydave
Joined Jun 22, 2012
11,395
Just noticed that the amp has the mains input, and will have the transformer, the service manual will show which pins on the ribbon cable turn the amp on/off.
Have you tried it without any modules connected?
Dodgydave
Joined Jun 22, 2012
11,395
It will probably need an ON signal from any module, which maybe 5V , it's knowing which pin is needed.
You will probably have to buy the service manual, can't find any sites with free download.
Rabbitbreth
Joined Jan 22, 2019
188
here's a copied piece from another post on the earlier model SU-CH7
. I'm guessing that a digital signal is sent to the the amplifier from the tuner via the ribbon cable (via 'Bus Data' which is pin 4 on the 11 pin ribbon cable connector and pin 5 on the 13 pin ribbon cable connector). I suspect that this digital signal triggers the amplifier to switch from 'standby' to 'on'. A work around could possibly be to some how replicate a triggering signal on pin 4/5. In my previous post I though someone might be able to measure this triggering signal if they have the tuner that goes with the amp.
MEDOJOSIP
Joined Oct 11, 2020
it is working!!! Thanks a lot...
Only problem is after 5-10min eq block and there is no sound. Also only one channel works but I think the problem is with amplifier. I mean, what do I expect fot 6$??
27,528
Thanks for all of the information, and especially that service manual.
The service manual does provide detiled instructions on how to operate the amplifier by itself. That should be valuable, if any are able to utilize that information.
And I am now thinking that I will chose to not ever get any Technics equipment that is set up like that.
ToTaL'69
Joined Jul 15, 2022
Hiya!
So did this get resolved sufficiently to know what you connect where?
Don't you just feed one of the strip wires to one of the other strip wires to complete the circuit?
Surely it would take a simple solder job wire to connection, wire to connection...?
Unless the equipment needs a flow between the tuner so it reminds the equaliser to stay active? (as would be the fault latterly mentioned with equaliser and sound drop....)
27,528
It is not that simple to access the conductors in a ribbon cable, and in addition, that would prevent it from being used with the other sections again.
Malogic
Joined Feb 29, 2024
Please tell us how you solved the problem. Did you bridge two contacts or was it some 3,3/5V input? Which pins?
Rabbitbreth
Joined Jan 22, 2019
188
Mine is working fine on its own without the other modules. Its been so long I forgot what I did but it cant have been too technical . I must have just bridged the contacts .
