I stopped my self from saying it.Changing the PSU caps may be a good idea but it's not going to stop this resistor getting charred.
And yes OP needs to confirm the Fan.
In order to test the fan I disconnected it and attached it to sequentially placed full AA batteries, first two then three. The 3 batteries gave 4,6v. The fan didn't react.And yes OP needs to confirm the Fan.
No, I didn't power up without the fan. I remember from the sound that I drew the conclusion it was running.Is the R573 smoking with the fan removed ?
And is it possible to measure voltages ?
Does the fan run nicely on 3V? If not it may be the problem.
Guess what guys... It doesn't! The resistor is fine without the fan. So likely I caused all on myself by putting the vacuum cleaner on top of it.If the resistor does not smoke without fan ..you need a new fan.
Isn't that simple... Searching internet for over an hour but can't find anyone selling it. Only posts from years ago of people running into out of stock issues. The ciiva link was also dead.Your Amp is fine and all you need is a new fan.
