Taser (High voltage) generator circuit messing with power supply
Status
Not open for further replies.
Afterlife301208
Joined Mar 25, 2024
Hello, I recently bough this mosquito racket and took out the guts and the electronics and attached it to a power supply (5V 1 Ampere). The taser circuit (mosquito racket guts) is messing with my power supply, it makes it turn on and off randomly, It even destroyed one of my power supplies. I am turning the taser on and off using a relay module controlled by an arduino which is powered by the same power supply
Any suggestions on what i should do to stop it?
Afterlife301208
Joined Mar 25, 2024
The problem is the racket guts and power supply is like 20cm away from each other and i cant change the distance because it has to be one unit
ericgibbs
Joined Jan 29, 2010
21,643
Hi After,
AAC rules do not allow Taser type devices.
Moderation
  • Restricted topics.The following topics are considered "out of bounds" and will result in your thread being closed without question:
    • Any kind of over-unity devices and systems
    • Devices designed to electrocute or shock another person
    • Jammers intended for actual use in other than legal academic contexts
    • Amateur/homemade rail guns and other high-energy projectile devices
  • If You come across a thread or post discussing any of the above topics please report the thread so We can close, and if necessary remove, the offending thread/posts.
Status
