I am designing a simple oscillator in ltspice. It's working perflectly fine, now I need to build it. The inductor of the tank circuit is 8.2uH I was thinking if I could use a fixed inductor (or whatever it's called, see the image) or if I should just stick with an air coil. This oscillator will be used in a radio transmitter. What would be the pros and cons?
Thanks.
Thanks.
