Syntax in the ArduinoIDE
tyro01
Joined May 20, 2021
87
Hi, I use ArduinoIDE 2.0.0. I am now looking at the BasicOTA.ino sketch.
This sketch is written in a grammar I am not familiar with in the following sections.
Code:
  ArduinoOTA
    .onStart([]() {
      String type;
      if (ArduinoOTA.getCommand() == U_FLASH)
        type = "sketch";
      else // U_SPIFFS
        type = "filesystem";
      // NOTE: if updating SPIFFS this would be the place to unmount SPIFFS using SPIFFS.end()
      Serial.println("Start updating " + type);
    .onEnd([]() {
      Serial.println("\nEnd");
    .onProgress([](unsigned int progress, unsigned int total) {
      Serial.printf("Progress: %u%%\r", (progress / (total / 100)));
    .onError([](ota_error_t error) {
      Serial.printf("Error[%u]: ", error);
      if (error == OTA_AUTH_ERROR) Serial.println("Auth Failed");
      else if (error == OTA_BEGIN_ERROR) Serial.println("Begin Failed");
      else if (error == OTA_CONNECT_ERROR) Serial.println("Connect Failed");
      else if (error == OTA_RECEIVE_ERROR) Serial.println("Receive Failed");
      else if (error == OTA_END_ERROR) Serial.println("End Failed");
Do these mean ArduinoOTA.onStart() or ArduinoOTA.onEnd()?
Can I write and call this code in another .ino file?
Thanks in advance,
tyro01
Joined May 20, 2021
87
Hi ericgibbs, The website you shared with me was very helpful. The website has a large number of posts in the comments section, indicating a high level of interest in OTAs. I have found the idea of separating the sketch about OTA from the user sketch. I will include the code here so that I do not forget the steps.
Code:
#include <ESP8266WiFi.h>
#include <ESP8266mDNS.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
const char* ssid = "your ssid";
const char* password = "your password";
void setup() {
  Serial.begin(115200);
  Serial.println("Booting");
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
  while (WiFi.waitForConnectResult() != WL_CONNECTED) {
    Serial.println("Connection Failed! Rebooting...");
    delay(5000);
    ESP.restart();
  // Port defaults to 8266
  // ArduinoOTA.setPort(8266);
  // Hostname defaults to esp8266-[ChipID]
  // ArduinoOTA.setHostname("myesp8266");
  // No authentication by default
  // ArduinoOTA.setPassword((const char *)"123");
  ArduinoOTA.onStart([]() {
    Serial.println("Start");
  ArduinoOTA.onEnd([]() {
  ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
  ArduinoOTA.onError([](ota_error_t error) {
  ArduinoOTA.begin();
  Serial.println("Ready");
  Serial.print("IP address: ");
  Serial.println(WiFi.localIP());
  OTA_setup(); // user setup
void loop() {
  ArduinoOTA.handle();
  OTA_loop(); // user loop
