Synology DS1815+(SMD) damage what is the replacment part?
Warren_K
Joined Oct 8, 2022
1
WOW!!!!!
I guess while I was doing a memory upgrade I some how managed to bump the component off. and now doesn't power up.
It just clicks, Atom resistor fix done some years ago.
I would like to replace it but have no idea what part it is.
Synology DS1815+ U37 ( I guess it's a power mosfet or voltage regulator?? But I have no idea the value etc etc)
HELP HELP HELP!!!
Any help Greatly appreciated
Thanks Warren.
SamR
Joined Mar 19, 2019
5,528
Welcome to AAC!
DS1815 Datasheet catalog 3.3V EconoReset with Push-Pull Output
The DS1815 EconoReset uses a precision temperature reference and comparator circuit to monitor the status of the power supply (VCC). When an out-of-tolerance condition is detected, an internal power-fail signal is generated which forces reset to the active state. When VCC returns to an in-tolerance condition, the reset signal is kept in the active state for approximately 150ms to allow the power supply and processor to stabilize
Should be an easy replacement. There are a few versions however.
