This graph shows a single line to ground fault occurring on line A of a 3 phase system.
Va is red, Vc blue.
At first I thought Va had went to ground. But its actually in behind Vc. It's almost as if Va has halved and taken on the characteristics of Vc.
This is going to sound like a stupid question, for someone at my level. But clearly those lines aren't completely isolated from each other. Right?
I spend most of my time with math. I'm slightly in the dark when it comes to the real thing.
Has the voltage halved across the two lines or something?
That might result in, half the magnitude and the same phase angle, which corresponds to the results I seem to be getting
Va is red, Vc blue.
