I have been working on a project that generates dual output voltage (+15/-15) from a 12v battery. The circuit I have made consists of a mosfet H-bridge across a transformer's primary coil. The transformer is wound with 2 secondary coils. The purpose of the H-bridge is to produce a square wave( Vpp = 24v ) from a 12Vdc battery. The turns ratio is selected to produce a square wave ( Vpp - 30v ) across the secondary coil. I have selected the turns ratio such that the transformer's core doesn't go into saturation.
Iam using IRF540 mosfets in the H-bridge. The mosfets are driven at 1Khz switching frequency from high and low side drivers as shown in the schematics.
The problem is the voltage across the tranformer's coils doesn't maintain a square wave shape. It is like a ramp. Voltage starts at the maximum and keeps falling during the switching period. Can someone explain the reason behind this.
Below Iam attaching the schematics and the voltage waveform picture.
Thank you.
Coil voltage waveform
Mosfet H-bridge
High-side driver
Low-side driver
Thank you.
Mosfet H-bridge
High-side driver
Low-side driver
