Switching capacitors with analog Mux
E_enthusiast
Joined Aug 20, 2020
31
I was wondering if it is possible to switch the capacitor which with two resistors forms the astable configuration in a 555 timer using a CD4051 analog multiplexer
dl324
Joined Mar 30, 2015
18,480
Welcome to AAC!
It depends on the circuit. Post a schematic so we can see if you'd be stressing the switches.
ronsimpson
Joined Oct 7, 2019
4,845
Connect the smallest capacitor directly to the NE555. Then through the CD4051 add more caps in parallel to make larger values. I know you will have to do a little math but; The oscillator will run more stable. The effects of the 4051 will be less.
E_enthusiast
Joined Aug 20, 2020
31
Thank you for the advice, I really appreciated it
Current through the multiplexer will be less than 1mA, so it should work.
Cropped, brightened image:
Thanks for everything.. appreciated
schmitt trigger
Joined Jul 12, 2010
2,260
You did not indicate the Vcc value.
The “on” resistance of a CD405x multiplexer is reduced significantly with increasing voltage.
The 555 will support 15 volts, as the CD40xx logic does, so try to use that voltage.
schmitt trigger
Joined Jul 12, 2010
2,260
If you only have +5 volt available, use the 74HC4051 version.
I ran precisely into this problem years ago with the CD40xx devices, but the 74HC40xx were an order of magnitude better. From memory.
Google the datasheet for actual values.
