As best as I can figure, with R2=R3=47K and R4=3.3K, it should switch on at R1=48.7K, and switch off at R1=53.6K, which should be enough hysteresis to prevent any chattering. Fitting a ln() function through your three points, I get R1=317534-73079*ln(C), where C is temperature in deg C. At C=40, R1=48K, so it should be turning on at ~40degC.Yes #14 works. All i want is an on/off fan switch Ian so i'm not bothered about PWM. as i said though i could do with it coming on at a lower temperature so what resistors should i change? Something i've noticed also is that when i'm gently warming the sensor up with the soldering iron underneath, the motor will start slowly at first for a few seconds until it gets even warmer and then it suddenly starts fully, when the motor is running slowly the chip does get warm. it always switches off suddenly when cooling down.
If it continues to turn on partially, it could be that the 12V is not well regulated? Try increasing R4 to 4.7K.
