Hello, and thanks in advance for giving this a read. I have done my research and I'm seeking help on a best option before committing to learning how to implement the best one.
Project -
Two dashcams and one Powerpack Battery.
Goal - key on - switch dashcams power source from Powerpack Battery to car 12v (5v inverted). Begin charging Powerpack Battery. Isolate battery supply side from cams.
Key off - Switch cams power supply back to Powerpack Battery. Isolate car fuse box.
I first considered using transistors as switches but because Powerpack Battery supply needs to come on when12v goes off, I thought maybe a normally closed relay would be best. A quick search showed a lot of these but all are 40 amp or more (switch currents too high). Each cam only draws about 0.6 amps. It seems that a single relay and a diode to isolate the battery leg of the circuit is a possible solution but not sure where to find correct part.
I started thinking about Arduino Uno. I know that device is overkill but it's also cheap and simple. I'll hold these questions for the Arduino section if this turns out to be the better option.
Q- Is there a simpler way to achieve this goal?
Q - Can I find a NC relay in the 1 amp range?
Q - Arduino Uno?
Project -
Q - Arduino Uno?
