Switch Design
squirtle
Joined Nov 6, 2023
Hello guys,
I want to design a kind of switch with 5V input and 5V output. If input is below or above 5V, circuit should provide 12V output.
Thanks,
squirtle
Joined Nov 6, 2023
Lets say input should stay between 4.5V and 5.5V, in that case output must be 5V but if input gets below 4.5V or above 5.5V, output must be 12V.
Ya’akov
Joined Jan 27, 2019
10,357
Welcome to AAC.
Could you please describe the problem this circuit is supposed to solve? Without some idea of application this thread is going to turn into a guessing game and the help you get won’t be very good.
Understending why you want this will fill in a lot of things you would never think of to tell us umprompted.
28,527
"Y" is right: tell us the problem to be solved instead of asking us how to implement what you have decided is the solution.
In addition, that is a rather nebulous description of the system.
28,527
It will take more than a single comparator to detect above and below some limit. And still, until the actual project is explained along with the more detailed requirements there is no reason to spend time on guesses.
I am not trying to be hostile, but trying to solve an undefined problem is not what I do.
MaxHeadRoom
Joined Jul 18, 2013
30,881
I used one, plus a couple more components in order to regulate the field of a 50HP DC generator! :cool:
Ian0
Joined Aug 7, 2020
13,311
If you derive the 5V supply from a higher voltage supply using a switched-mode IC such as LMR38010, then it will provide you with a "power good" output which does (almost) what you need.
