Thanks. I haven’tIf you can measure the resistance of the LDR when lit or dark, as well as measure the voltage (to ground) of both sides of the LDR when lit or dark (four measurements), it possible to use a switch to select between two resistors put in place of the LDR. This may require a SPDT push button switch. Share your results here.
Here's a basic idea of how an LDR controlled circuit might work: (see image below)
Light changes the resistance which changes a voltage going to a comparator. Depending on the design the circuit does its thing. If you replace the LDR with the circuit (two resistors and a switch) pressing the button will change the voltage at the comparator the same as it does with the original LDR.
There are two ways of hooking up an LDR, one will drop the voltage the other will increase the voltage, depending on how it's wired. So my proposed change may or may not work. That's why more information is critical to finding a good solution to your problem.
Those are cool. I have some lights here that are activated by a little spring wiggling - in my “find out how that works some time” pile.Google Vibrator Switch & many types will be displayed including cutaways of my favorite, VIVS W-18010P.
I have discovered this is the toy https://www.amazon.com/The-Roffle-Mates-Laughing-Alligator/dp/B002TMVYXO It is motion activated and the only other information I have is that where the LDR is in the PCB it reads V+ 330k V- 560kSome questions I have that may be germane to the issue, how does the toy work? By that I mean if you block the LDR does the toy react for a set period of time controlled by the electronics within the toy? Or does it only react during the time the light has been blocked?
Also, if it's LDR, how do you stop the toy from running all night (or all day - depending on its operation)?
In the most general terms, as you already know, an LDR changes resistance with the exposure of light. It shouldn't be too hard to substitute the LDR with a switch and a couple resistors. The two resistors set up a voltage divider (don't worry if this is over your head, you'll catch on). The voltage divider will act like the LDR in the sense that it is now providing an unchanging and constant division in the voltage. Since the LDR requires a change in light levels to cause a change in the resistance, a switch in parallel with one of the two resistors can do the same thing in that when you push the button you change the voltage (same as the LDR will do) and activate the toy.
Before we start throwing schematics at you we need to understand a little more about the toys operation. That's why people are asking for more specific information. If you can manage to get that info to us I'm confident someone here will be able to come up with a brilliant and simple solution to the problem.
Good luck.
It's now plausible to think you are not dealing with an LDR but rather a PIR detector (Passive Infra Red). If the toy is motion activated then you don't need a switch. This should be even easier to use by a child who's mental capabilities are not on par with contemporary children.I have discovered this is the toy https://www.amazon.com/The-Roffle-Mates-Laughing-Alligator/dp/B002TMVYXO It is motion activated and the only other information I have is that where the LDR is in the PCB it reads V+ 330k V- 560k
Here is a photo of it. I have PIRs and they look different. And the children can’t make purposeful movements to activate something that requires motion as they are quadriplegic. Some have switches they activate with their heads because it’s the only part of the body they have control over and even then only with neck bracing to support the head. They also frequently have CVI which is cortical vision impairment meaning their eyes are fine but the brain doesn’t interpret. So they can’t locate the area that requires motion, even if they could do it. That’s way I struggle because they need have to be toys that move so the child can hear the movement, and sound. And lights though I haven’t gotten to adding lights into the equation yet.It's now plausible to think you are not dealing with an LDR but rather a PIR detector (Passive Infra Red). If the toy is motion activated then you don't need a switch. This should be even easier to use by a child who's mental capabilities are not on par with contemporary children.
If it IS a PIR detector then fixing it will be a little more involved than simply replacing it with a switch. I'm sure a switch could be bodged into the circuit, but now the child has to touch something, whereas previously all they had to do was come within its field of detection. I'm not the one to assist you with PIR; so I think I'm probably done with responding to this post as I don't think I can add anything useful to you.
And apologies, I am dealing with children with physical disabilities (primarily cerebral palsy) and they frequently don’t have intellectual disabilities although people often assume they do because they can’t do anything without assistance and are frequently non-verbalIt's now plausible to think you are not dealing with an LDR but rather a PIR detector (Passive Infra Red). If the toy is motion activated then you don't need a switch. This should be even easier to use by a child who's mental capabilities are not on par with contemporary children.
in an effort to not be insensitive to those with disabilities. Please excuse my lack of understanding in such manor. I've not been placed in any circumstances to ever have to deal with such a handicap.This should be even easier to use by a child who's mental capabilities are not on par with contemporary children.
See post #27. Photo shows LDR and not PIR.I think that The PIR can be paralleled or replaced with an appropriate external switch if enough information can be gleaned.
Where are you located?
I am in Perth, Western Australia. I am waiting on some replacement equipment I need - once it arrives I will start experimenting with the toy. It’s seems there is a fault that is not related to the LDR which I currently can’t find. He definitely works because I can get him to operate by bypassing the circuit entirely and just providing an external power source directly to the motor. Finding faults in PCBs, for me, is just dumb luck - there is just so much I don’t know! I know components and what they all do, it’s the circuitry that baffles me because I don’t have a schematic and I guess you can “read” the board but that’s not a skill set I haveI think that The PIR can be paralleled or replaced with an appropriate external switch if enough information can be gleaned.
I am not sure what you are asking. The “motion sensor” was a small black spout between his eyes and in my photograph it’s the two brown wires at the front of the board, next to the screw in front of the motor.Roffle is " Motion Activated". " and when he passed it " Gator" started laughing", so as I had suspected the shiney round thing in the shell top
might be a speaker, post # 12 picture. I still have no clue as to where the LDR fits in.
Might there be different Roffle models ?
Pressure switches can be made from Velostat, a pressure sensitive plastic sheeting of
which I have some samples also some samples of tilt switches & vibrator switches.
These are the switches that cause the most problems - they couldn’t be simpler but for some reason they consistently don’t fulfil their purpose. I also have switches operated by magnet - useless in my toys but I now have a collection of incredibly strong magnets that may be useful sone dayRoffle is " Motion Activated". " and when he passed it " Gator" started laughing", so as I had suspected the shiney round thing in the shell top
| Thread starter | Similar threads | Forum | Replies | Date |
| D | Switch identification help | Datasheets, Manuals & Parts Identification | 8 | |
| D | Advice on wiring a switch | General Electronics Chat | 15 | |
| K | DC Snubber Protection On a ON-OFF-ON Cam Switch | Power Electronics | 6 | |
| T | Referee RF Mic inline Switch | General Electronics Chat | 5 | |
3PDT switch pop | Analog & Mixed-Signal Design | 13 |
