Referee RF Mic inline Switch
TDDoug
Joined May 10, 2026
7
I've been trying to put an inline on/off switch for a football referee wireless mic. The mic itself is an electret mic which receives power from the bodypack transmitter. The switch i am using is a DPST rocker.
The power AND audio both travel down the same wire and connects to pin 1 of a mini XLR. Pin3 contains gnd, pin 2 is blank.
I have looped the power/audio line directly through the body pack to the mic to maintain constant power to the mic. From that same line I am running to the switch, A1 side, through a 10mf electrolydic capacitor. The gnd goes to the A2 side with a 10K bleeder resistor between the A1 & A2 poles.
It should mute the mic audio but it does not mute it completely, there's audio bleeding through when in the off position. There's also a small pop I can see on the oscilloscope, roughly negative 20mv. It doesn't always pop. The biggest problem has been the leaking audio, its about 70dB down from the on position but it is there and never 100% completely mutes. It can't be heard in the PA but it is heard on the broadcast.
Second try, ran the mic directly through A1 and the output through A2 to the transmitter. Completely kills the audio in the off position but I'm getting a larger pop, plus and minus voltage swing.
I've tried a .1mfd cap in series with the input but get the same pop.
Looking for some other ideas for this simple fix that's become not so simple.
Appreciate any input.
Best regards,
Doug
28,520
It seems like the need is to mute the microphone audio. What we get is no description of how the system works, does the transmitter switch off when the microphone is not conected?? If that does, is that a problem?? Many radios open the DC path thru the microphone connection to switch off the transmitter.
So please describe in more detail.
What would make the most sense is what is very common in radio links, which is PUSH TO TALK, where the transmitter is only active when the switch is pressed.
I am guessing that the receiver is feeding a PA system, is that the case??
28,520
More questions, needed to avoid us HAVING TO GUESS about things!
Questions: is the transmitter on constantly? Or is it on only when the referee wants to announce something??
What about the receiver?? Does it have squelch, so that there is no output when the RF signal is not present??
REALLY!! That makes a very big difference in the solution to the problem.
Normally, in a system where the microphone is not constantly on, the operation mode is "Push To Talk", meaning that the "connection", in this case the transmitter, is normally OFF, AND the receiver audio out is normally SQUELCHED, so that nothing is heard from that source.
WEneed to know more about the existing system.
AND, what are A1 and A2, mentioned in the post?? I can only guess that they might be pins on that mini-XLR connector.
Do you have ANY information on thatwireless microphone system??
T General Electronics Chat 10
Similar threads
Referee Mic Pops on/off
