Swapping components on servo tester
North_south_cosplay
Joined Aug 1, 2019
16
Hey guys. So I've successfully "extended" the components of my servo tester so I can position them inside a spiderman mask easier but I was wondering if any of you with your infinite wisdom could suggest something I could replace the attached picture with. In a certain mode it allows you to move the servo with the dial but i was hoping to have a much simpler button that I can press with my chin etc. If it would be too much hassle to change then I'll probably just make do but better to ask :) thanks in advance
MaxHeadRoom
Joined Jul 18, 2013
30,794
I assume you need a chin operated pot to control the servo position?
Some kind of spring operated pot, linear rather than rotary maybe.
Max.
djsfantasi
Joined Apr 11, 2010
9,237
@crutschow,
Not if he only needs two positions. I’d measure the pot from wiper to each end, which would give me four values or two voltage dividers. With a SPDT momentary push button switch, he could select one of two dividers, and thus pressed is one position and not pressed gives the other.
MaxHeadRoom
Joined Jul 18, 2013
30,794
It depends on how the servo is presently controlled, using a 12F pic you can go to graduated positions from fully CW to CCW in for e.g. 20 positions from one to the other.
Max.
djsfantasi
Joined Apr 11, 2010
9,237
Yes, if the TS wants to start over again. So far, he’s decided to use a servo tester module and wants to replace the continuous control provided by a potentiometer, with a way of hard-wiring two positions. Any other servo position is not desired nor necessary.
North_south_cosplay
Joined Aug 1, 2019
16
Yeah I'll be using micro linear servos as I only need up and down movement. Whilst the ability to choose how far I want the lenses to close would be ideal it's a little difficult to operate inside my mask. I didn't know if there was another component you guys might know of that could easily replace it or be easier to operate using a chin haha. It was here that I found out about servo testers. So far you guys have been extremely helpful. But yes I technically only need 2 positions. Open and closed.
North_south_cosplay
Joined Aug 1, 2019
16
I also apologise in advance for being completely ignorant to abbreviations. So don't feel like you're patronising me. Dumb Dumb language works best with me hahaha. Thanks again for all your ideas. Hoping you guys can find a solution for me.
North_south_cosplay
Joined Aug 1, 2019
16
It was off Ebay. I'll find the link now if you want and yeah at the moment its using a variable pot in mode 2 (it has 3 modes) to control the position of the servo
Wolframore
Joined Jan 21, 2019
2,619
It may be a 555 or a small 8 bit microcontroller... either way main function is to change the pulse width of the squarewave and it's a small package with everything you need.
It shouldn't be difficult to wire up a button to it.
It could be as simple as determining what the max resistance is; then put a resistor parallel with a pushbutton. When you hit the button it gives zero resistance... you will have to play and measure what the pot does to determine the correct values and wiring.
