Swap NE555 timer chip with cmos LM7555 timer chip
ericgibbs
Joined Jan 29, 2010
21,601
hi happirt,
A problem maybe the input current requirement of the circuit driven by the 555.
The 555 TTL max Iout is approx 100mA to 200mA , the CMOS version is limited approx 5mA or so.
Do you have copy of the circuit of the module you have linked.
E
ericgibbs
Joined Jan 29, 2010
21,601
hi,
The 555 pin #3 Out is driving a Resistor/LED, also the IRF540 Gate.
Looking a the component values for the LED and Gate I would say a CMOS 555 would not be suitable.
The LED is drawing more current from pin #3, than a CMOS could supply.
E
ericgibbs
Joined Jan 29, 2010
21,601
hi,
Looking at the IRF540 datasheet, I would suggest you could try it without the LED.
On a low current load test, monitor the temperature of the IRF.
Are 555 unavailable in your area.?
E
bertus
Joined Apr 5, 2008
23,014
@ericgibbs , Where did you find the 5 mA output current?
I only can find an absolute maximum output current of 100 mA in the Intersil datasheet if the icm7555, wich is a cmos version of the LM555.
Bertus
ericgibbs
Joined Jan 29, 2010
21,601
hi,
The TLC555 Vhigh output, which is required for Gate drive, from the d/s is listed as this image., for Vdd =15v
E
EDIT:
This is for a ICM7555
ericgibbs
Joined Jan 29, 2010
21,601
@bertus.
I have suggested to the TS that he tries his CMOS 555 [ without driving the LED] , he may just get the result he needs.
Hope he comes back and posts his findings.
E
happirt
Joined Aug 12, 2017
18
I have updated the diagram, hoping someone can help me...
I think the problem is the green ground connection, I'm not sure where to connect to for it to work?
