MaxHeadRoom
- Joined Jul 18, 2013
- 30,815
So by Servo's, you mean RC servo's.!
Yeah sorry mate, as I said I have very little experience working with actuatorsSo by Servo's, you mean RC servo's.!
Well this is a kind-of school project (not really, it's under a robotics club) so we are keeping it relatively low-scale. The idea is to get a nice amount of precision on it more than anything else.That must be a rather small robot arm to be running on 5 volts.
The smallest robot I have programmed was powered by 20 amp/208 volt 3-phase power. The joint motors were AC servo types, brushless 3-phase variable speed.
You don't need to use 14AWG wire for the power. It has a resistance of 2.58mOhms/ft. At stall current of 2A, the wiring will drop the voltage by 5.16mV/ft which is negligible.We plan on using 7 servos - 2 20kg-cm servos (2.7 A each), 1 40 kg-cm servo (≈ 4 A), 1 6kg-cm servo (1 A), 3 microservos (0.8 A each), hopefully controlling them using a Raspberry Pi Pico (if possible) or Raspberry Pi 4. Now I don't have any specific details on the longest leads but I could see the longest reaching MAX 60-70 cm. These wires will likely be 14 AWG in accordance with current ratings.
