Suggest a flywheel diode for solving back emf problem
Status
Not open for further replies.
Srikanth Allamsetty
Joined Apr 5, 2017
15
Hi, I am trying to make a variable frequency supply unit using 555 timer, TLP250 driver, a mosfet P80NF55, and a flyback transformer 1V/250V. I need to drive a capacitive load (Plasma reactor) at 10 kV, 0.1 A, if the frequency is 3kHz. Circuit diagram is attached herewith. Before connecting the flyback transformer, I am getting variable frequency pulses across MOSFET (between drain and source). But when I connect the MOSFET (drain) through the primary of flyback transformer to the DC supply, I think MOSFET is burning. I have seen it not working later when I test it alone again removing flyback transformer.
I understood that there was a back emf problem due to inductive nature of the circuit. So, to reduce it, I need to connect diodes across coil and across MOSFET.
My applied voltage is 15 V at primary and maximum current is 25 A in primary side, when secondary gets 0.1 A.
So, what could be the rating of the diode that suits this application.
Thanks in advance.
38,883
You need a zener or transzorb across the MOSFET source to drain rated at about 75% of the MOSFET's voltage rating.
You do not need (or want) any flyback diodes across the coil as that will drastically reduce the output voltage.
Note that your diagram shows a P-MOSFET, not the N-MOSFET it is.
Status
