Hi,The sub-threshold region will cause the mosfet to heat up more than other regions of use, due to it having the most "on" resistance.
From wikipedia:Hi,
Could you please site an example fo the application of subthreshold region of operation of MOSFET.
Thank you.
An example could be a linear audio power amplifier using (complementary) MOSFETs for the output.Hi,
Subthreshold operation is normally used at very low currents for Class A micropower (or nanopower) circuits.An example could be a linear audio power amplifier using (complementary) MOSFETs for the output..
