substitute battery
frankciruit
Joined Jul 8, 2017
3
I have a AA battery case with two batteries in series. Each one outputs 3.7v.
Can I substitute a single 7.4v battery and place it on one side of the battery pack. Assume amps are the same ?
Usually batteries are rated in mA-Hours or Amp-hours. You can replace with smaller or larger with either reduced or increased run-time. Battery chemistry determines the charging profile.
frankciruit
Joined Jul 8, 2017
3
to follow-up, am i correct that in one battery slot I can make a dummy battery that has a wire running through it, that connects the pos and neg terminals and the other that just connects the terminal ends (pos & neg) that come from the power source (no wire running through it)?
