Submission in progress, 555 Schmitt Trigger
Wendy
Joined Mar 24, 2008
23,857
OK, I've been able to definatively prove it is a corrupt script file that is the heart of the <OMEGA> markup issue. I did this by converting the output html file to .txt, and looking at it. There is an added "amp;" in the string. When I looked at the script file as a .txt file it was there, but is hidden in html format.
The SubML file is complete. For future testing purposes I need good copies of the script files. The only way I can do this (short of retyping them by hand) is either get a .tar decompressor for XP or get them packed in .zip.
How do I get the OMEGA ohms symbol in the forums? Thanks.
Wendy
Joined Mar 24, 2008
23,857
Almost have it...
changing the [ to a {
{tex}\Omega{/tex}
10K\(\Omega\)
10K\(\Omega\)
But if I do a straight cut n paste from other posts it looks much better...
10 KΩ
I just wonder if there is a direct way of typing the latter in.
Ah well, enough off topic.
Wendy
Joined Mar 24, 2008
23,857
I found a decompressor that works here...
http://www.majorgeeks.com/Simplyzip_d5393.html
It's a bit clunky, it will extract the files in the same directory as the compressed file, but it works. I now have SubML worked out enough to use. Should I .zip them up for other people?
I've updated the my submissions .zip file file here...
http://forum.allaboutcircuits.com/showpost.php?p=72989&postcount=6
Allow me to rephrase, here is the .zip file of the SubML documents.
gerty
Joined Aug 30, 2007
1,305
I learned about the shortcut keys a long time ago andthe Omega is the only one I use on a regular basis. I have a short list in my work 'puter and I'm at home now, I'll post them tomorrow. Anyways there is a "character map" that has all of this, you just drag-n-drop.
Start
Programs
Accessories
System tools
Character Map
Pick your font style and go from there, the Omega is available in several
styles. there is also stuff like:
® ¶ ¼, you get the drift.
Glad to contribute.
gerty
Joined Aug 30, 2007
1,305
Found them..
alt 0131 ƒ
alt 0177 ±
alt 0178 ²
alt 0179 ³
alt 0181 µ
alt 0186 º
alt 0188 ¼
alt 0189 ½
alt 0190 ¾
alt 0247 ÷
alt 0248 ø
Hope this helps you out..
Wendy
Joined Mar 24, 2008
23,857
Definately an improvement. I probably need to write em down or put them in my blog. Thanks again.
Dave
Joined Nov 17, 2003
6,969
Bill, I have read the 555 Schmitt Trigger article and confirm that I am happy with the content, as long as you are happy with the circuit functionality. If so, then I am happy for Dennis to go ahead and add the article to the Experiments Volume.
As for the character maps, AFAIK this will only work with numbers on the Num-pad. We actually had these synbols back in the Invision days here at AAC, however when we upgraded to vbulletin we only went for the LaTeX editor - perhaps there is scope for a few common symbols.
Dave
Wendy
Joined Mar 24, 2008
23,857
OK, I'll still do it, and let you know the results. Been busy at the Marsden household, graduation, and other events all crowded together for the first week. I plan on building off this layout with other ideas.
