Submission, CMOS 555 Long Duration Blue LED Flasher
Wendy
Joined Mar 24, 2008
23,816
Article: Proof Read
Illustrations: Complete
Experiment: Schematic Verified
Duration Test Started 8/1/09
CMOS 555 LONG DURATION BLUE LED FLASHER
PARTS AND MATERIALS
  • Two AAA Batteries
  • Battery Clip (Radio Shack catalog # 270-398B)
  • One CMOS TLC555 timer IC (Radio Shack catalog # 276-1718 or equivalent)
  • Q1 – 2N3906 PNP Transistor (Radio Shack catalog #276-1604 (15 pack) or equivalent)
  • Q2 – 2N2222 NPN Transistor (Radio Shack catalog #276-1617 (15 pack) or equivalent)
  • CR1 – 1N914 Diode (Radio Shack catalog #276-1122 (10 pack) or equivalent, see Instructions)
  • D1 – Blue light-emitting diode (Radio Shack catalog # 276-311 or equivalent)
  • C1 – 1 µF Tantalum Capacitor (Radio Shack catalog 272-1025 or equivalent)
  • C2 – 100 µF Electrolytic Capacitor (Radio Shack catalog 272-1028 or equivalent)
  • C3 – 470 µF Electrolytic Capacitor (Radio Shack catalog 272-1030 or equivalent)
  • R1 – 1.5 MΩ ¼W 5% Resistor
  • R2 – 47 KΩ ¼W 5% Resistor
  • R3 – 2.2 KΩ ¼W 5% Resistor
  • R4 – 620 Ω ¼W 5% Resistor
  • R5 – 82 Ω ¼W 5% Resistor
CROSS-REFERENCES
Lessons In Electric Circuits, Volume 1, chapter 16: Voltage and current calculations
Lessons In Electric Circuits, Volume 1, chapter 16: Solving for unknown time
Lessons In Electric Circuits, Volume 3, chapter 4 : Bipolar Junction Transistors
Lessons In Electric Circuits, Volume 3, chapter 9 : ElectroStatic Discharge
Lessons In Electric Circuits, Volume 4, chapter 10: Multivibrators
LEARNING OBJECTIVES
  • Learn a practical application for a RC time constant
  • Learn one of several 555 timer Astable Multivibrator Configurations
  • Working knowledge of duty cycle
  • How to handle ESD sensitive parts
  • How to use transistors to improve current gain
  • How to use a capacitor to double voltage with a switch
SCHEMATIC DIAGRAM
ILLUSTRATION
INSTRUCTIONS
NOTE! This project uses a static sensitive part, the CMOS 555. If you do not use protection as described in Volume 3, Chapter 9, ElectroStatic Discharge, you run the risk of destroying it.
This circuit builds on the previous two experiments, using their features and adding to them. Blue and white LEDs have a higher Vf (forward dropping voltage) than most, around 3.6V. 3V batteries can’t drive them without help, so extra circuitry is required.
As in the previous circuits, the LED is given a 0.03 second (30ms) pulse. C3 is used to double the voltage of this pulse, but it can only do this for a short time. Measuring the current though the LED is impractical with this circuit because of this short duration, but blue LEDs are generally more predictable because they were invented later.
This particular design can also be used with a single 1½V battery. The base concept was created with a now obsolete IC, the LM3909, which used a red LED, the IC, and a capacitor. As with this circuit, it could flash a red LED for over a year with a single D cell. When newer red LEDs increased their Vf from 1.5V to 2.5V this old chip was no longer practical, and is still missed by many hobbyists. If you want to try a 1½V battery change R5 to 10Ω and use a red LED with a better CR1 (see next paragraph).
CR1 is not the best choice for this component, it was selected because it is a common part and it works. Almost any diode will work in this application. Schottky and germanium diodes drop much less voltage, a silicon diode drops 0.6-0.7V, while a Schottky diode drops 0.1-0.2V, and a germanium diode drops 0.2V-0.3V. If these components are used the reduced voltage drop would translate into brighter LED intensity, as the circuits efficiency is increased.
THEORY OF OPERATION
Q2 is a switch, which this circuit uses. When Q2 is off C3 is charged to the battery voltage, minus the diode drop, as shown in Figure 1. Since the blue LED Vf is 3.4V to 3.6V it is effectively out of the circuit.
Figure 2 shows what happens when Q2 turns on. The capacitor C3 + side is grounded, which moves the – side to -2.4V. The diode CR1 is now back biased, and is out of the circuit. The -2.4V is discharged through R5 and D1 to the +3.0V of the batteries. The 5.4V provides lots of extra voltage to light the blue LED. Long before C3 is discharged the circuit switches back and C3 starts charging again.
In the LM3909 CR1 was a resistor. The diode was used to minimize current, by allowing R4 to be its maximum value.
You may notice a dim blue glow in the blue LED when it is off. This demonstrates the difference between theory and practice, 3V is enough to cause some leakage through the blue LED, even though it is not conducting. If you were to measure this current it would be very small.
Wendy
Joined Mar 24, 2008
23,816
OK, this experiment is basically completed. The blue LED is a high brightness unit that lights up the entire living room. Now to see how long it lasts, the duration test is now running.
Wendy
Joined Mar 24, 2008
23,816
This one is also going strong. It is also noticably dimmer, but still blinding. I suspect the basic concept is plain more efficient than the other designs.
Wendy
Joined Mar 24, 2008
23,816
Well, that was easy, around 7:00PM tonight, 10/31/09, it dimmed dramatically. No gradual fade out here, though it is still flashing dimly. I like it when an experiment is so neat and clean like this. I'm debating whether to modify it with a simple constant current source and use a red LED, for maximimum life. Whatcha think?
bertus
Joined Apr 5, 2008
23,005
Hello Bill,
The current source will also take some current for itself.
This will shorten battery life a bit.
You could try a fet as current source, this will only drop some voltage.
The current will be depandend on the type of fet used.
Greetings,
Wendy
Joined Mar 24, 2008
23,816
I'm aware of the fet variaty, but you can't program them (I think). I've got another design that will work, not a totally flat current curve, but it will work. When I get a chance I'll put it up.
Wendy
Joined Mar 24, 2008
23,816
The thing I don't like about that approach is several, you don't get the same value with different parts, and the part have to be easily available (Radio Shack again). They have an experiment where this is done in the book, which I thought was cool.
The approach I was thinking of doing was something like this...
