Stunned, hooked up my first SDR
ApacheKid
Joined Jan 12, 2015
1,762
I just hooked up my first SDR, petty basic I know:
and I'm running this with AirSpy SDR# for Windows, but it is truly astonishing, I had no idea this was actually possible at this insanely low price!
Ya’akov
Joined Jan 27, 2019
10,367
There are also great console programs like the ADS-B decoder dump1090 that let's you watch the transponders of aircraft as they fly over, and rtf_433 that is a data decoder for things like key fob remotes and TPS sensors, as well as a bunch of other things. It targets 433.92MHz, but you can tune to 315MHz (some car remotes), 915MHz (ISM band data), or anywhere else for that matter.
ApacheKid
Joined Jan 12, 2015
1,762
Fascinating, it's truly amazing stuff, when I was studying radio and electronics in college in the late 1970s, this was unimaginable.
ApacheKid
Joined Jan 12, 2015
1,762
So if we can do this with 2 GHz RF signals, why can't I also buy a 40 dollar gadget and observe at 2 GHz bandwidth on a software scope on my PC?
Seeing a 2GHz signal with a few (2.4) MHz bandwidth is magnitudes easier than having a device with 2GHz measurement quality bandwidth. I have a 6GHz HackRF One 20MHz bandwidth with a cost of hundreds more.
WBahn
Joined Mar 31, 2012
33,342
Because the SDR is not sampling at the 4+ GHz that would be needed to have the scope you are talking about.
It is mixing the RF signal with a local oscillator signal to shift it down to a MUCH lower frequency. This is then usually downshifted again to baseband and then sampled with a (relatively speaking) slow A2D. The RTL-SDR has a maximum guaranteed sample rate of just 2.56 MHz and only seven bits of effective resolution.
ApacheKid
Joined Jan 12, 2015
1,762
OK here's another question, this is a local FM station and it seems to occupy a very large frequency span:
Is this right? does that station need 400 MHz? or even the narrower part that's 200 MHz? Isn't a FM broadcast channel meant to use no more than 200 KHz?
ApacheKid
Joined Jan 12, 2015
1,762
OK I see. we're primarily interested in the modulating signal in the case of these SDR devices and that is as you both point out, a much lower frequency that's being sampled.
Ya’akov
Joined Jan 27, 2019
10,367
I know you've already worked out your error but the thought of an FM broadcast station needing an order of magnitude more bandwidth than the entire allocated band is scary.
If we start broadcasting in the THz band, that's different.
ApacheKid
Joined Jan 12, 2015
1,762
Yes, there are some scary things going on. I studied radio formally (as part of a two year full time course in electronics and telecommunications) in college in the very early 80s and it was my hobby for at least six years prior I had no money but had several old tube radios and built several basic radios too, I used to "DX" a lot in a disused back kitchen, unheated, with a long wire running around the perimeter of the yard.
I got a QSL card once too, from Korea if I recall!
The stuff going on today is mind blowing, I recall making a radio from a ZN414 made by the UK's Ferranti, today I'm fiddling around with an nRF24L01 and yesterday I was reading about Nordic's newer chips, it is stunning how things have changed.
