Struggling with C and PIC16f1825
Torbek
Joined Apr 19, 2019
83
So I trying to learn to program in C
My boss has sent me a file that compiles for the PIC16f648, and I am trying to convert to the PIC16f1825, but currently struggling, especially with the sendbits commands...
Can anyone please guide me in the right direction?
Code:
// CONFIG1
#pragma config FOSC = INTOSC    // Oscillator Selection (INTOSC oscillator: I/O function on CLKIN pin)
#pragma config WDTE = OFF       // Watchdog Timer Enable (WDT disabled)
#pragma config PWRTE = ON       // Power-up Timer Enable (PWRT enabled)
#pragma config MCLRE = OFF      // MCLR Pin Function Select (MCLR/VPP pin function is digital input)
#pragma config CP = OFF         // Flash Program Memory Code Protection (Program memory code protection is disabled)
#pragma config CPD = OFF        // Data Memory Code Protection (Data memory code protection is disabled)
#pragma config BOREN = OFF      // Brown-out Reset Enable (Brown-out Reset disabled)
#pragma config CLKOUTEN = OFF   // Clock Out Enable (CLKOUT function is disabled. I/O or oscillator function on the CLKOUT pin)
#pragma config IESO = OFF       // Internal/External Switchover (Internal/External Switchover mode is disabled)
#pragma config FCMEN = OFF      // Fail-Safe Clock Monitor Enable (Fail-Safe Clock Monitor is disabled)
// CONFIG2
#pragma config WRT = OFF        // Flash Memory Self-Write Protection (Write protection off)
#pragma config PLLEN = OFF      // PLL Enable (4x PLL disabled)
#pragma config STVREN = ON      // Stack Overflow/Underflow Reset Enable (Stack Overflow or Underflow will cause a Reset)
#pragma config BORV = LO        // Brown-out Reset Voltage Selection (Brown-out Reset Voltage (Vbor), low trip point selected.)
#pragma config LVP = ON         // Low-Voltage Programming Enable (Low-voltage programming enabled)
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
#define _XTAL_FREQ 4000000
#include <xc.h>
char digitcode[10] = {126,24,109,61,27,55,119,28,127,31}; // setup the 7 segment data that correspond to the digits 0..9
// set up holding values for each 7segment display
// set all segments ON for initial test
char A0 = 255;
char A1 = 255;
char A2 = 255;
char A3 = 255;
char B0 = 255;
char B1 = 255;
char B2 = 255;
char B3 = 255;
char C0 = 255;
char C1 = 255;
char C2 = 255;
char C3 = 255;
char bitcnt = 0;
char RXbyte;
char RXbytetemp;
char RXchan;
int RXcnt;
char DPRX;
void LatchIt(){
    __delay_us(50);
     RC1 = 1; // latch pin high
    __delay_us(50);
     RC1 = 0; // latch pin low
void SendBits(char digit1, char digit2,char digit3, char digit4){
    // this function sends the bits for display
    //------------------ 1st digit -----------------------------
    for (bitcnt=0;bitcnt<=7;bitcnt++){
        __delay_us(50);
        RA2 = 1; // clock pin high
        __delay_us(50);
        if ((digit1 & 0x80) == 0x80){
           RC0 = 1; // data pin high
        else{
           RC0 = 0; // data pin low
        digit1 = (unsigned char)(digit1 << 1);
        __delay_us(50);
        RA2 = 0; // clock pin low
    //---------------------- 2nd digit --------------------------
        __delay_us(50);
        __delay_us(50);
        if ((digit2 & 0x80) == 0x80){
        else{
        digit2 = digit2 << 1;
        __delay_us(50);
    //----------------------- 3rd digit ------------------------
        __delay_us(50);
        __delay_us(50);
        if ((digit3 & 0x80) == 0x80){
        else{
        digit3 = digit3 << 1;
        __delay_us(50);
    //----------------------- 4th digit -------------------------
        __delay_us(50);
        __delay_us(50);
        if ((digit4 & 0x80) == 0x80){
        else{
        digit4 = digit4 << 1;
        __delay_us(50);
        // return clock to high to finish
        __delay_us(50);
void main(void) {
     // set up i/o
    CM1CON0    = 0x00;    //comparitor off
    CM1CON1    = 0x00; //comparitor off
    ANSELA = 0x00;
    ANSELC = 0x00;
     PORTA = 0x0F;
     TRISA = 0x00;   // all portA are outputs
    TRISC = 240; // set RX & TX pins to inputs
    BRGH = 1;
    SPBRG = 25; // set baud rate to 9600 Baud (BRGH = 1) 4MHz internal XTAL
    SYNC = 0;   // async comms
    TX9 = 0;    // 8 bit TX
    TXEN = 1;   // enable TX
    SPEN = 1;   // enable serial port
    CREN = 1;   // enable RX
    RX9 = 0;    // 8 bit RX
    CREN = 0; // reset any errors
    CREN = 1;
    // at this point we need to check for received data
    // ignore all chars except 0..9, A,B,C, space, decimalpoint and carriage return
    // only update displays when a valid sequence of recieved data is received
    // A123.4 <CR> is a minumum type of TX
    //A123.4B567.8C901.2 <CR> is a longer type
    // a decimal point will add 128 to the next data value
    SendBits(0,0,0,0);
    SendBits(0,0,0,0);
    SendBits(0,0,0,0);
    LatchIt();
    // 2 second delay
     for (bitcnt=0;bitcnt<=20;bitcnt++){
         __delay_ms(100);
         CLRWDT();
    SendBits(0,0,0,0);
    SendBits(0,0,0,0);
    SendBits(0,0,0,0);
    LatchIt();
      __delay_ms(200);
    SendBits(1,1,1,1);
    SendBits(1,1,1,1);
    SendBits(1,1,1,1);
    LatchIt();
      __delay_ms(200);
    SendBits(3,3,3,3);
    SendBits(3,3,3,3);
    SendBits(3,3,3,3);
    LatchIt();
      __delay_ms(200);
    SendBits(7,7,7,7);
    SendBits(7,7,7,7);
    SendBits(7,7,7,7);
    LatchIt();
      __delay_ms(200);
    SendBits(15,15,15,15);
    LatchIt();
      __delay_ms(200);
    SendBits(31,31,31,31);
    LatchIt();
      __delay_ms(200);
    SendBits(63,63,63,63);
    LatchIt();
      __delay_ms(200);
    SendBits(127,127,127,127);
    LatchIt();
      __delay_ms(200);
    SendBits(255,255,255,255);
    LatchIt();
    // 2 second delay to check operation of LCD segments and PCB LED
         __delay_ms(100);
         CLRWDT();
    RC3 = 1; // LED Off
    __delay_ms(800);
    RC3 = 0; // LED = OFF   RC3 = 1; // LED Off
    __delay_ms(800);
    RC3 = 1; // LED = OFF
    RXchan = 'X'; // select no channel (i.e. A.B or C)
    // loop forever
    while(1==1){
        CLRWDT();
        if (TRMT == 1){
            TXREG = 0x55;
    // need to check for received data and act upon it if a valid sequence
    // if a received error then rest the comms
    // have we received any comms
        if (RCIF == 1){
            if (OERR == 1){
                // if here we had an overrun error on RX comms
                // read and throw away any byte received
                RXbyte = RCREG;
                // so reset comms
                 CREN = 1;
            else{
                // if here then a character has arrived
                // valid characters are 0..9, decimal point, Carriage Return,
                // A, B, C
                // throw away all others
                RXbyte = RCREG;
                // any of the chars A ,B or C restart the RXcnt
                if (RXbyte == 'A'){
                    RXcnt = 0;
                    DPRX = 0;
                    RXchan = RXbyte;
                    //clear all chars for channel
                    A0=0;
                    A1=0;
                    A2=0;
                    A3=0;
                if (RXbyte == 'B'){
                    RXcnt = 0;
                    DPRX = 0;
                    RXchan = RXbyte;
                    B0=0;
                    B1=0;
                    B2=0;
                    B3=0;
                if (RXbyte == 'C'){
                    RXcnt = 0;
                    DPRX = 0;
                    RXchan = RXbyte;
                    C0=0;
                    C1=0;
                    C2=0;
                    C3=0;
                if (RXbyte == '.'){
                    DPRX = 1; // acknowledge the decimal point
                if ((RXbyte >= '0') & (RXbyte <= '9')){
                    RXbytetemp = RXbyte - '0'; // convert to number
                    RXbytetemp = digitcode[RXbytetemp];// convert to digit code
                    if (DPRX == 1){
                        RXbytetemp = RXbytetemp + 0x80;// add DP to character
                        DPRX = 0; // reset DPRX has it as been used
                    // need to put the value into the correct channel
                    if (RXchan == 'A'){
                        //this was the last channel selected
                        if (RXcnt == 0){
                            A3 = RXbytetemp;
                        if (RXcnt == 1){
                            A2 = RXbytetemp;
                        if (RXcnt == 2){
                            A1 = RXbytetemp;
                        if (RXcnt == 3){
                            A0 = RXbytetemp;
                    if (RXchan == 'B'){
                        if (RXcnt == 0){
                            B3 = RXbytetemp;
                        if (RXcnt == 1){
                            B2 = RXbytetemp;
                        if (RXcnt == 2){
                            B1 = RXbytetemp;
                        if (RXcnt == 3){
                            B0 = RXbytetemp;
                    if (RXchan == 'C'){
                        if (RXcnt == 0){
                            C3 = RXbytetemp;
                        if (RXcnt == 1){
                            C2 = RXbytetemp;
                        if (RXcnt == 2){
                            C1 = RXbytetemp;
                        if (RXcnt == 3){
                            C0 = RXbytetemp;
                    if (RXcnt<5){
                        RXcnt++;
                        // if RXcnt = 5 then character ignored
                 if (RXbyte== 0x0D){
                      if (RC3 == 1){
                          RC3 = 0;
                      else {
                          RC3 = 1;
                     // carriage return received so send out what we have got
                     SendBits(A0,A1,A2,A3);
                     SendBits(B0,B1,B2,B3);
                     SendBits(C0,C1,C2,C3);
                     LatchIt();
                      RXchan='X'; // just to prevent RX being stored without
                     // a channel A,B,C being sent first
    return;
dl324
Joined Mar 30, 2015
18,413
You might get some help if you described the problem you're experiencing. Is it failing during compile or runtime?
Also be aware that many of us have a line we don't cross for work related questions because we don't work for free.
