You give no details on the clock circuit, but grounding the passive (non- driven) leg of the crystal should do the trick.I have an IC tester that works in-circuit. But it needs the clock/crystal stopped. What would be a safe way to stop the clock without removing the crystal? Do I just ground one lead or both leads with a resistor?
Russ
And how do you propose to do this on an existing, functional PCB board?Use a logic gate to gate the clock.
You have knowledge of the circuit in question that is not in evidence?Use a logic gate to gate the clock.
TS exhibit TS0000You have knowledge of the circuit in question that is not in evidence?
Which clock? The IC tester, or the board being tested?I have an IC tester that works in-circuit. But it needs the clock/crystal stopped.
