stm32cubeide c++ led blinking example
rt694157
Joined Dec 15, 2019
78
I have STM32F407 board I want to start c++ program on it it is very very hard for me to create c++ programming on it
Here is my steps
Next
Next
Next
Next Next Finish
When I click on finish button I do not get option to write program
dl324
Joined Mar 30, 2015
18,476
I've never used the board or IDE in question...
Have you check if it created a file for your project that you now need to open?
402DF855
Joined Feb 9, 2013
271
Looks like Eclipse, I'd suggest finding an alternative. It sucks. Still, you should be able to bring up the project explorer and find your source file.
402DF855
Joined Feb 9, 2013
271
Yeah, you can see I have two projects, rrrrr and ttest. They don't compile. Apparently the standard libraries are not setup by default. As I said, Eclipse sucks.
35,222
ARM chips are not the same as an Atmel AVR, TI MSP430, or Microchip PIC.
You have to jump through hoops in order to flash an LED.
Which version STM32CubeIDE are you running?
The latest version is v1.2.1.
You ought to be using the automatic HW configuration and SW code generator.
It will initilize the hardware and generate a code template for you.
rt694157
Joined Dec 15, 2019
78
I am using v1.0.0 STM32CubeIDE
I have been trying some steps to create / run c++ program. What are the steps to create c++ program to blink led in STM32CubeIDE ?
35,222
Start with:
File > New > STM32 Project
If you are using an STM32F407 board open the Board Selector tab.
If you are going bare bones, open MCU/MPU Selector tab.
35,222
Ok so far.
Now pick the GPIO pin that you wish drive the LED.
Go to the STM32F407G-Discovery User Guide and pick one of the LEDs on the board.
