Steps to design a receiving antenna ?
Externet
Joined Nov 29, 2005
2,681
Hi.
What is the proper sequence of thought to design, build, install and test/evaluate a receiving antenna ?
Papabravo
Joined Feb 24, 2006
22,115
Use a long wire for the first two
Use a quarter wave whip and a decent ground plane for the other four.
Receiving antennas don't need to be that precise because they are not handling power or dealing with reflections.
Irving
Joined Jan 30, 2016
5,195
True, but if the kit is available it doesn't hurt to plug in a signal generator and a VNA and check the matching to ensure maximum sensitivity.
I found this site useful.
LowQCab
Joined Nov 6, 2012
5,102
If maximum Signal-Strength is your goal,
you must think in terms of a resonant Transmitting-Antenna, tuned to a specific frequency.
Otherwise, a coat-hanger might work.
The problem with a "Broad-Band" Antenna
is that the Receiver must be able to filter-out everything else,
and there will be a ton of trash to filter-out,
some of which may overload the Front-End of the Receiver,
masking, or even obliterating, the signal that you want to hear.
A tuned-Antenna will not be as sensitive to ~99% of that unwanted Noise.
