Stencil cutting laser
cmartinez
Joined Jan 17, 2007
8,853
Anyone here knows if there's an affordable desktop-sized laser machine out there capable of cutting 0.012" stainless steel for solder paste stencils?
Danko
Joined Nov 22, 2017
2,231
https://www.alibaba.com/product-det...796.html?spm=a2700.details.0.0.444fc08b2kSlJY
Feature:
【90W effect laser beam cutter】Our laser engraver uses the latest 5.5W laser beam shaping technology blue diode laser, it has an ultra-fine 0.06mm sharp laser focus, with super cutting penetration and precision, it can cut up to 15mm thick wood, 10mm acrylic,carve ceramics and stainless steel, this is almost beyond the effect of 90W CO2 laser.
【Fast focusing and safe design】Our powerful laser etching machine has the fastest focus design. It combines a fixed focus lens and a slider. You only need to slide the laser module and tighten the screws to complete the focusing. Very easy and convenient. Meanwhile the laser machine equipped with a power switch, which is not available in others. Fixing holes are reserved on the four feet and the body structure to facilitate fixing the machine and the data cable.
【New eye protection design】The laser protective cover perfectly protect your eyes,filter UV light for 98%. You and the people around can watch laser engraving without wearing goggles. Reduce the cost of your goggles and the inconvenience of wearing goggles, prevent pets and children from grabbing the laser spot.
cmartinez
Joined Jan 17, 2007
8,853
View attachment 298464View attachment 298465
Feature:
Thank you, Danko. I've already looked at machines of that type ... but I'm very scheptical about their true output power. Somehow 90W doesn't seem realistic to me when one considers the price ... do you have first hand knowledge or experience with those machines? Or do you at least know somebody who owns one of them?
Edit, I just read the following ifo:
5.5W is much more believable than 90W ... I hate it when the Chinese confuse you with their sloppy handling of units ... Would 5.5W be enough to cut through 0.012" stainless steel? I wonder
ErnieM
Joined Apr 24, 2011
8,415
I've seen apps to translate Gerber files to G code so you may 3D print a stencil.
I made one stencil for a board that never got made.
cmartinez
Joined Jan 17, 2007
8,853
Thanks, Ernie. I have two 3d printers and I've already tried that ... it didn't work out. Especially with chips having only a 0.65mm pitch.
